Trace Reference is so slow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-11-11 05:43 AM
This is to make the selection on the Pet Palette Edge just so hard to zoom just barely and AC froze.
While I stop the work by activating the Trace Reference such as this will lead to the AC quit at any time, turn off some layers remain the same even very slow.
In the list of repairs
194 286 SPEED: Navigation on Floor Plan was very slow when both the Trace & Reference and the Renovation palette were turned on.
Why no change?
What effect does this apply to the use of OS ?, Windows 10 is so very slow.
Doing enlargement Curve Edge Palette will also be inaccurate.
Can I have the same opinion given through this?
Urgently need to speed this improvement in AC19
Please GS
- Labels:
Performance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-06-12 04:54 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-06-12 05:07 AM
If so try docking them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-06-14 09:16 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-04-03 12:23 PM
What I learned about the trace reference is that you have to have as few elements showing on the trace settings page. One that slows everything extremely is the use of showing dimensions as it has to calculate everything two times.
Experiment with what to show and you'll be surpriced to see how much impact it has on your workflow.
My two cents,
Dominicus
db-architects ltd
Dominicus Björkstam
Finland
AC 24 latest build, localized FIN version
Hardware MacbookPro 15" i9 + 32GB Ram + Windows Desktop (win10)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-10-30 07:59 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-11-03 11:16 AM
Sebastián wrote:Dear Sebastián,
Im using AC 24.0.0 v1 SPA (3008) It gets so slow it's impossible to work with trace reference active.
Thank you for the report and I am very sorry for the issue!
If you are using a saved view as tracing reference, this could significantly slow Archicad down (depending how complex the file is), as it will try to display 2 different settings at once (one from the saved view and one from the current opened window). I'm wondering if this is the case?
If not, could you make a small video showing the issue? Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-06-15 06:28 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-06-17 10:33 AM
riyadist wrote:Hello,
Same problem, couldn't fine any solution
Thank you very much for sharing the issue and I am very sorry for the experience!
First, I would like to make sure that you have the latest update for Archicad installed. Currently, the newest official update for Archicad 24 is 500x. Could you let me know whether the issue persists on 500x?
Furthermore, I would like to ask whether the suggestions above help you with the issue?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-06-19 10:52 AM
mnguyen wrote:Hello, archciad 5000 update seems work faster. It fixed a bit.
Best regards,
Minh
- « Previous
- Next »
- « Previous
- Next »
