ā2005-10-05 01:04 AM
ā2005-10-05 01:11 AM
ā2005-10-05 01:18 AM
ā2005-10-05 04:39 AM
Scott wrote:Try listing with "Tree by Masters" instead of "Tree by Subsets" and you will see if the master is being used by anything.
Stewart,
Excellent thought. I've done a cursory check confirming each layout's master layout, but non seem to be connected to the offending master layout.
ā2005-10-05 05:47 AM
Try listing with "Tree by Masters" instead of "Tree by Subsets" and you will see if the master is being used by anything.I don't see how "Tree by masters" shows the master to sheet layout. The "Layout List" does indicate masters used per sheet, however in my case no sheet layout is linked to the offending master layout. It's starting to sound like this may be some type of screwed up file condition.
ā2005-10-05 09:58 PM
Scott wrote:Click on the + to the left of the master name, it expands to show you which layouts it is assigned to. If there is no + it is not used. (it's o.k. i only found this out yesterday looking into this)
Barry, thank you by writing:Try listing with "Tree by Masters" instead of "Tree by Subsets" and you will see if the master is being used by anything.I don't see how "Tree by masters" shows the master to sheet layout. The "Layout List" does indicate masters used per sheet, however in my case no sheet layout is linked to the offending master layout. It's starting to sound like this may be some type of screwed up file condition.
Thanks so much Barry & Stewart.
ā2005-10-05 10:32 PM
ā2005-10-05 10:48 PM
ā2005-10-06 04:28 AM
Scott wrote:
I noticed that the offending master layout was set to 'Default' shown with the 'bent corner' indicator.
s2art wrote:Never realised there was a "default" setting.
We all missed that one.too.
ā2005-10-06 04:20 PM
Barry wrote:There is; it is supposed to be your most used layout size.
