For some reason, selecting drawings or primitives either by Shift Clicking or using the Arrow Tool including Magnate has ceased to function within any and all layout sheets within one PLN file. This is a major problem as nothing can be individually selected.
In layout sheets of the subject PLN, we can select all using Control A, but not using Marquee, Arrow or Shift Click. Also, the origin has moved on its own to the lower left hand corner of the sheet, and cannot be relocated. Further, we are unable to draw primitives or place text on any layout sheet within that file, and Alt Clicking to pick-up parameters does not function. Selection including with Arrow Tool and Alt-Clk'g works as expected in the model environment.
We have New & Reset as well as restarted the system several times without luck. No other programs are running. Other smaller PLN files are fine. The file with the issues is 38 MB. We are open to any and all suggestions. I'm hoping this is not the unspecified file size limitation mentioned in the manual.
Thanks,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
