2022-11-29 01:12 PM
In AC26 updates it is shown that 4022 build is released, it quite strange that NOR version have bigger build number than INT version 4019 (4022 > 4019) and what is more strange that NOR don't have 4019 build. Also in "List of Improvements" its missing what was updated in AC26 4022 NOR build update.
Solved! Go to Solution.
2022-12-08 09:37 AM
4019 and 4022 are compatible. Teamwork works within 100 range, so technically all 40xx builds are compatible with each other.
Noémi Balogh
Community Expert, Admin
2022-11-29 02:53 PM
German version is on 4022 as well.
2022-11-29 02:59 PM
As I see AC26 German version have no issues of missing AC26 4019 build and not missing list of improvement to 4022 build 😞 Unlucky Norwegians 😉
2022-11-29 03:59 PM
If I remember correctly there was just one thing different. 4022 is a hotfix for 4019, not much has changed.
2022-12-02 12:08 PM
it was two last-minute template modifications:
Plan files saved by different hotfix versions are compatible, and existing plan files weren't affected by this.
2022-12-02 04:12 PM
Will it be AC26 update 4019 build for NOR version ?
2022-12-08 08:35 AM
No, there won't. Of course update 4022 contains all fixes done for 4019.
2022-12-08 08:54 AM
My point was not only about updates but about collaboration, that is not possible between different builds 4019 and 4022.
2022-12-08 09:37 AM
Noémi Balogh
2022-12-08 09:38 AM
Never knew that, thanks for a tip 😉
