Upgrade to OS 10.3.9-HELP!!
An hour ago I let the Mac software update do its thing and upgrade the OS to 10.3.9. Then opening a .pln i discovered that all "histories" seem to have vanished. There is no Work Environment that I have customized. It's not even listed. All files ask for all librarys to be loaded, everything outside of the individual pln's is back to start!! That's what I mean when I use that technical term history. Even Safari has lost the bookmarks and history.
Anyone else having behavorial problems after point 9 ?
I have run disk utility since upgrading which may be part of the problem ???
WatchIt !
Wally
Upgraded to 10.3.9 yesterday without any problems. I did make sure that I upgraded Archicad first, then upgraded the Operating system. No loss of workspace or safari bookmarks. I posted the upgrade on our server and we had some in our office run the upgrade across the network. Two had archicad not run and had to re-install and re-upgrade; one worked fine. Also the re-installs kept their workspace!
I just upgraded to 10.3.9 and the April security update and everthing is working fine.
Thanks Millard & Karl,
Local Mac wisdom says that if you upgrade OS do it separately and run Disk Utility for permissions before you install the Security upgrade. Maybe that's just for G4's with retread processors (?). Thankfully my back-ups came thru.
Wally
