Very slow Copy/Cut in AC10
Eduardo Bell
I'm wondering why when selecting even simple lines or even a line, and choose the copy command, it takes forever to process before the arrow appears back to be able to perform a paste action. Then the paste is as fast as before with AC9
I do have a G4 but in AC9 the cut and copy work very fast even with very complex info.
Anything I can do other than buy a new machine?
Thanks
USA v4.55 to v28-b3001 OS Sonoma v 14.6.1
MacBookPro 8-Core Intel i9 16GB ram
AMD Radeon Pro 5500M 4GB vram
Perpetual License Subscriber
10 REPLIES 10
jbArch
I had the same problem, and my reseller suggested that I should change my netwok/internet settings.
Go to the network panel in system preferences, and enter your DNS server numbers in the TCP/IP settings. This is "optional" for the OS, but for some reason has an impact on archicad.
May just be snake oil but it seemed to make a difference in my AC10.
JB
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
Eduardo Bell
Thanks JB,
Had that already in place. I got rid of a few DWG reference drawings I had imported and closed off all other applications and the function improved to an acceptable level of speed. I guess my problem is really below standard hardware, I'm grateful it works. Love 10.
We have similar problems. But for me, it is not exactly clear what i have to enter for the dns-server number.
Do i have to enter the ip-address of our file-server?
Or do i have to enter the ip-address of the router, wich delivers dhcp-ip-numbers?
Thanks
I'm having this problem today - just started in 10 on a new small outbuilding (get into 10 slowly!). I'm on a PC with Windows XP Pro on an office network license.
The TCP/IP settings on this PC are set to "obtain an IP address automatically" and "obtain DNS server address automatically".
Our CAD manager is away over the Christmas/New Year break.
Intel (R) Pentium (R) 4 CPU; 3.00GHz; 2GB RAM
Jefferson
Hi Guys -
This is an old problem that seems to raise it's ugly head from time to time..............
The best [and most popular] tried + true method for unlocking/speeding up cut/copy is, navigate to the file folder your project is in and select the containing folder, then reselect the .PLN file. This almost always cures it, for most of us Windoze users. [Only some specs in signatures so just assuming Bill's software, never heard of this on MAcs.] If this doesn't get it, do a search of copy freeze, lockup, slow or some other iteration and you'll find plenty of other ideas..........Hope this helps and good luck!
Kind of refreshing to see a post where people aren't hurling WMDs at each other
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
Do you mean from inside the "Open" dialogue within the AC application, or from the Explorer?
(I like to think of myself as a Mac user (by choice) and a Windows user only by circumstance (work environment)).
Thanks for the advice. This morning I was going to apply it, but it seems to be working fine today.
So long since I've regularly looked at the Talk, that I haven't noticed that - I'll use this quiet period to try to catch up on current posts, methinks ...
Jefferson
Good Morning Kim -
Yes, from internet explorer..........in particular, keeping an explorer window open makes it faster. It is specifically discussed here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=6859&highlight=copy+nvidia
along with other ideas and historical perspective
My troubles with this demon have only rarely showed up since I upgraded to 10 from 8.1, and it even "self-fixes" most of the time now Who knows?
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
Thanks Jeff I will definitely remember it now!
This did happen to me quite a lot before, but hasn't happened to me at all on this computer (almost a year) until I moved to 10. My fixing measure in past instances was much harsher than advised here - being a restart.
Jefferson
Glad to be of assistance.............I was going nuts when this was happening nearly every time, it's like a bad dream now, thank God!
Hope the cure stays!
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
