Installation & update
Video Card and anti-aliasing 3D
In AC 16 on a MacPro with an ATI RADEON 4870 512 Mo it is impossible to active "Anti-Aliasing" in 3D with open GL (it was OK in AC 15.
Is it a bug ?
Is the video card ATI Radeon 5770 HD - 1 Go is compatible with "Anti-Aliasing" in 3D with open GL ?
Thank you
9 REPLIES 9
This is a known issue that is expected to be fixed via a hotfix at some point:
http://www.archicadwiki.com/Bugs/AntialiasingNotAvailableWithCertainVideoCards
http://www.archicadwiki.com/VideoCardsForArchiCAD16#Mac_Specific_Recommendations
One of the forum moderators
I have a radeon hd 5750, and the bug its present too.
All AMD (ATI) cards apparently exhibit this problem on OS X until the hotfix is released.
I think so, the old imac with HD2600 has the bug too, but the macbook pro with nvidia works well.
In my imac with mac os 10.8.2 antialiasing has come back!!!
Interestingly, after the hotfix, antialiasing is enabled in my WE - Mac with ATI 5770 - but I do not see any antialiasing happening - jaggies everywhere still.
Success:
I had to manually edit the plist as described here:
to set the '3D Shaded Feedback Fallback' value to 1. The article suggested the ArchiCAD would do this automatically, but it did not.
Everything looking smooth now. 🙂
My imac has a radeon hd 2600 and archicad 16 3014 version, not the new hotfix.
Karl, as you can see from my profile, I recently upgraded to the ATI card and I also cannot toggle the requester for antialiasing in ArchiCAD 17. Would you have any suggestions? Thanks!
jbArch
I was experiencing this same problem even though my video card is NOT on the list of problematic cards. (NVIDIA GeForce GT 750M 2048 MB)
I tried resetting the SMC to make sure my mac knew which card to use, but the problem persisted. (Note: I have not tried the plist tweak mentioned by Karl, since I don't like the negative side effects).
Ultimately I ended up downloading the CUDA driver directly from Nvidia. This seems to greatly improve the antialiasing for me.
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
