2021-05-06 12:28 AM
2021-05-06 02:48 AM
2021-05-06 03:36 AM
Barry wrote:Hiding/showing the tabs didn't change anything. [Didn't check the Window menu; only now I understand what you were saying.] Closing all other didn't close it. I open-and-repaired, which this being a TW file sucked considerably, but that's life, and that did it.
Turn the TABs off and back on again.
If you go to the WINDOWS menu, does it show in the list of open windows there? (probably not).
Select the floor plan tab, right click and 'Close all other Tabs & Windows'.
Open the file with 'Open and Repair' (through the FILE menu > Open File).
2021-05-09 10:51 PM
2021-05-11 09:03 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-05-20 04:57 PM
mnguyen wrote:I couldn't reproduce it when I opened that teamwork file from a new AC update, not sure if related. But the issue has since appeared with the latest update too –this time when it happened I closed without saving, and the problem was not there when I reopened. It might be related to the session/user and not the file. Any news, I'll message.
I'm wondering if this issue can be reproduced only in Teamwork, or also in a local PLN save of the project? Do you still have a copy of it, where the issue can happen?
