WALL REFERENCE LINE
Takis
Hi, I have this problem:
While drawing a wall, if first accidentally pass my mouse over "Guide Line" or "Cutting Plane" then "Reference Line Location button" gets disable and doesn't get back to enable, so I cannot flip the wall.
I have to press escape and pick again to draw another wall.
(See attachment)
Archicad 19 build 5005
Windows x64 via Bootcamp.
MacPro Late 2013
Takis
8 REPLIES 8
You are not alone on this one. Indeed I never figure out why this was happening, but now that you just say it I went and realize that, that is the problem, when you pass the mouse by Guide lines, this happens. And also is still happening in AC20, just tried.
While this is solved, when drawing walls in chained method, you can click to create the first wall, then hit backspace to go back one click and the option will become available again.
Takis
Hi, thanks for the answer. It is good to have choices but since this is happening also in AC20 I think Graphisoft should take care of it.
I believe they just didn't notice that this is a bug.
Takis
Yeah, probably no one reported. I hope the Graphisoft people from this forum will see this message and take care of it, is nothing mayor, but is annoying
Katalin Borszeki
Hello Takis,
Thank you for your report about this issue, we’ve added it to our database and plan to fix it in the near future.
best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Thanks Katalin!
Stress Co_
Try the P and C keyboard shortcuts.
Don't be controlled by the Wall Reference Line
Marc Corney, Architect
Red Canoe Architecture, P. A.
Yeahh! Why I didn't knew this before. I'll probably will never feel it again
