WIBU key problem
I have Archicad 9 at my office and have just purchased a Dell Dimension pc so I can also work at home. I needed to fit a parallel port PCI card as the pc only had USB ports and my key is parallel. When I load Archicad I get the message that the protection key has not been found, I tested the new port with a printer and it is ok. I uninstalled and then installed Archicad again with the key plugged in but it still will not work. Office pc is Windows xp pro, home is xp Home, could this be the problem.
Any suggestions ?
7 REPLIES 7
Ben Odonnell
Hi Richard,
XP Home should not be a problem. If you down load the latest WIBU drivers from their web site www.wibu.com
That should do the trick for you.
HTH.
Cheers.
Ben
Ben O'Donnell
Thanks Ben, I will try downloading the driver.
regards
So did this help? I have the very same problem. I have Microsoft Windows XP Home Edition at home. I installed WIBU-KEY software from ArchiCAD 9 installation CD and then went on:
https://upgrade.graphisoft.com
where I got a prompt that it does not recognize WIBU key.
Downloading new driver didn't help neither.
Djordje
Install ArchiCAD WITHOUT the key plugged in.
When all the install is finished, restart the computer. Then plug the key in. XP will recognize the new hardware, and offer automatic install. Accept it.
The installation should go easily.
THEN start ArchiCAD.
It should work.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje. Just spoke to local distributor. Well, he sais that a whole series of dongles is faulty and needs to be replaced. Now we are waiting for new dongles from Budapest. So no home work this weekend! ...hmmm, that's not so bad actually...
Djordje
Not bad at all 😉
Djordje
HP Omen
Got a new dongle and it works fine now!
Anyway, thanks again...
