Wacom Mouse - orbit in 3D
Hi!
Does anyone know if there´s a way to orbit in 3d view with a wacom mouse (intuos 3) ?
It´s a bit backwards, workflow wise, having to swap mouse everytime I´m in Archicad...
Hoping for a solution...
Thanks,
Haavard
3 Replies 3
Dwight
I use a Wacom mouse against an Intuos tablet.
Works fine for Orbit.
What is wrong with yours?
Dwight Atkinson
When I go into 3d explore it´s almost imposible to navigate. The slightest touch on the mouse can take me lighyears away from the point where I actually want to be...
Maybe there are some settings that I´m not aware of?
With a normal mouse it works like a dream, but I would really like to make it work with the wacom as this is what I use for everything else.
Dwight
I have this overfast experience with Cinema 4D and its lovechild Maxonform. Maxon has a special tablet setting to fix.
But never in Archicad.
Attached are my settings for Archicad with Wacom. Set as fast as possible, considering the circumstances.
I suggest you check your mapping to cover as large an area as possible and also to force your mouse to mouse mode and not pen mode.
Dwight Atkinson
