ā2025-03-12
01:50 AM
ā2025-03-14
01:03 PM
Apple is releasing (finally) new Mac Studios tomorrow but there seems to be a lot of overlap between the M3 Ultra (the high end model) and the M4 Max (the entry model). Yes, even the naming is a bit confusing! The M4 is faster in single-core operations while the M3 Ultra is faster in multi-core. And the GPU in the M3 Ultra is better than in the M4 Max. Maybe I'm answering my own question here in the M3 Ultra would be faster running Archicad, if you're willing to spend 2x as much to get it.
Please save the "get a PC" comments for another post, that's not what this one is about! I actually have a PC I use for TwinMotion but I'd rather spend my days on a Mac, respectfully.
ā2025-03-12 02:17 AM
Depends ALOT on what projects you work on and how detailed/hardcore are you going with BIM/DD.
But if you ask me, go for the M4 Max. I have a M4 Pro regular mac mini and it does a fantastic job with medium/medium-large projects.
ā2025-03-13 08:43 PM
I'm interested in the same question. I'm currently working on a Mac studio M1 max with 32GB ram. In terms of performance, the M1 is OK, but 32GB RAM is not enough. I was planning on an M4 max with 96GB RAM, but it's not on offer. And at the price of 128GB, I'm already considering an M3 ultra with 96GB RAM. I'm choosing the higher ram because of the cloud points from matterport, so that I can process it. I create visuals in Lumion on a Win PC, but with higher RAM, Twinmotion could also work reliably on a Mac. I'd be grateful for any opinions and maybe I'll decide differently in the end....
ā2025-03-19 08:35 PM
I have had only bad experiences with Twinmotion, crashing on both mac and windows. I don't use it anymore, so i don't know what to say. Speaking of cloud points, i only ever worked with iphone lidar scans, and it always slowed archicad to a grinding halt. Dunno if ram is the problem, or the GPU, or just bad optimizations. I would test before making a decision.
ā2025-03-19 09:36 PM - last edited on ā2025-03-19 10:29 PM by Eduardo Rolon
Twinmotion also crashed on my Mac. It works on a Windows PC. I thought it was a RAM problem. So the problem is probably somewhere else.
As for Cloud point, I've tested it. Both from iPhone and Matterport. But you have to be sensitive with the amount of data. The maximum Cloud point file size of 2.5 - 3GB has proven to be successful in our work. I always process it in the freeware software Cloud compare and then import it into Archicad. I can't imagine working any other way (measuring with a meter...)
Currently, as I wrote, I have an M1 max, 32GB RAM.
I can't tell the difference between the M4 max and the M3 Ultra.
The M4 max with 128GB RAM is almost the same price as the M3 Ultra with 96GB RAM. And maybe the price-performance ratio will be enough for the M4 max, 64GB RAM.....
Twinmotion aj mne na Mac padal. Na win PC to bežĆ. Myslel som si že je problĆ©m v pamƤti RAM. Tak asi je problĆ©m inde.
Äo sa Cloud point týka, to mĆ”m odskĆŗÅ”anĆ©. Aj z iphone aj z matterport. Treba ale citlivo pracovaÅ„ s objemom dĆ”t. OsvedÄilo sa nĆ”m v prĆ”ci maximĆ”lna veľkosÅ„ sĆŗboru Cloud piojnt 2,5 - 3GB. Vždy si to spracujem vo freewer software Cloud compare a až nĆ”sledne to importujem do archicadu. Už si prĆ”cu ani inĆ”Ä neviem predstaviÅ„ (meraÅ„ metrom...)
MomentĆ”lne mĆ”m ako som pĆsal M1 max, 32GB RAM.
Neviem sa aale rozdnĆŗÅ„ medzi M4 max a M3 Ultra.
M4 max so 128GB RAM mĆ” takmer rovnakĆŗ cenu ako M3 Ultra 96GB RAM. A možo pomer cena výkon bude postaÄovaÅ„ M4 max, 64GB RAM.....
Please post in English.
I edited your post to add the translation.
another Moderator
ā2025-03-20 07:45 AM
Oh sorry. I don't know English. I'm writing through a translator. And I copied the untranslated text.... š
ā2025-03-25 10:31 AM
i only had good experience with Twinmotion since version 2019 using Invidia quadro and RTX GPUs. It's not fun on my M1 pro 16gb, but I didn't buy the macbook for rendering.
