alexandra
Wheel of death when Copying/ Pasting SE2016
I have a problem when I copy and paste in Archicad SE2016 in on of my project files. When I paste an item (any item) in a window or between windows it takes approximately 50 seconds to process. Any suggestions as to what is causing this? I am going insane.
Thnx
Alexandra,
Please always specify your OS version when posting an issue like this. "Wheel of death" suggests that you're talking about MacOS. SE2016 is only supported through MacOS El Capitan 10.11. So, if you are running Sierra or High Sierra ... and certainly if you're running Mojave 10.14, just released, problems are likely.
See: https://helpcenter.graphisoft.com/knowledgebase/54649/
https://helpcenter.graphisoft.com/knowledgebase/84821/
https://helpcenter.graphisoft.com/knowledgebase/74160/
