Installation & update
Where is the manual?
I recently purchased ArchiCAd 8.2 Student Version. Where is the manual? On the CD? Online? I have an eMac running OS10.3.5.
__archiben
go to your 'Help' menu - you should have a list of manuals there that launch as PDF's in acrobat reader. failing that, they should reside in the folder "Documentation" within the archiCAD application folder.
HTH
~/archiben
b e n f r o s t
Aussie John
I think from memory that the PDF archicad documentation needs to be specifically installed or copied fom the CD. I may be wrong on that.
Cheers John
[/size]
Nope, you're right. It's not part of the install process.
