Why is Archicad 22 way faster then Archicad 24
When same worksheet is imported in AC22 and AC24, AC24 is almost unusable (shutters, lags, takes a while to zoom in-out, change possitions etc.). AC22 works perfectly normal.
1 Reply 1
What are your machines specs and operating system?
What is on the worksheet?
I have found in the past when working with modules, that it is faster when the modules have been saved in the same version. Otherwise Archicad has to play around with library migration in the background.
Maybe something similar is happening here depending on the content of your worksheet.
