Installation & update
Window Markers
Newbie to Archicad!
When applying a Builders Dimension Marker to windows in an angular wall, the marker comes in up-side-down, are there any simple solutions to fix?
Hi Richard,
it would be a lot easier if you posted what OP system and ArchiCAD version you're on. Also, explain further what you are attempting to do (add a screendump if that helps). Which label tool have you selected for example?
Stress Co_
Richard wrote:
Newbie to Archicad!
Select the wall.
From the menu select: Edit > Modify wall > Invert Direction
Builder's dimensions care which "direction" the wall was created. If you go: Options > Clean wall & beam intersections... it will show the "direction" of the wall (Control 7 on my mac)
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
