2004-08-27 04:39 AM - last edited 5 hours ago by Molinda Prey
2004-08-27 07:03 AM
Lucia wrote:Play around with the window marker settings in the window settings dialog box
1. Please find attached windows with associated text. Is there a way for the text size to remain, keep associated with window, but move text to be read more clearly?
Lucia wrote:Yes it would. You can use walls for the vertical fascia of the bulkhead. Use appropriate layers (e.g. Ceiling? ) for it, so that it shows correctly in layer combinations, and don't forget the Display options for doors and windows!
2. I have a flat plasterboard ceiling at 2572mm which includes a raised ceiling in the centre of the room at 2872mm. Would this be constructed with the "Slab Tool"?
Lucia wrote:It is there in the standard library, all the standard profiles are listed.
3. I require a 200 UB (Universal Beam), are there any steel beams in the standard ArchiCAD library or do I need to draw from scratch? If so, would this be with the "Beam Tool"?
2004-08-27 11:06 AM
2004-09-08 03:39 PM
Lucia wrote:You adjust the Marker position using the Dimension settings from within the Door or Window dialogue box. See attached screenshot
Thanks for the reply.
1. I'm using the "Basic Window-Door Marker" it seems I can only change the text height and unable to relocate the text, as required.
2004-09-09 05:41 AM
2004-09-09 07:07 AM
2004-09-09 10:31 AM
2004-09-09 10:37 AM
2004-09-09 11:00 AM
2004-09-09 11:04 AM
