Window and Door Lables
Any one figure out a way to lable Door and windows in elevation/section.
I tried the Lable Elements check box but nothing shows up. It would be great is you could do this w/ the ID.
Thank you for your help.
Saul Sloan
1 Reply 1
TomWaltz
Label should work in elevation. Did you check in the Label Settings Menu to make sure that labels for doors are placed on a layer that's visible? (each tool within the Label tool has its own settings)
Tom Waltz
