ScottR
Work Environment moves toolbars when screen go to screensaver/sleep
I recently switched to an ultra wide screen monitor,, now whenever I first start Archicad, or whenever the screen saver comes on, Archicad moves my some of horizontal tool bars that go across the screen to a second row, (I guess to a non ultra wide screen width?) and I have to go to the menu to tell AC to use my default work environment to get my pallet layout back to the correct configuration - is there any fix for this problem?
Operating system used: Mac Apple Silicon 14 Sonoma
2 Replies 2
Guru
Might you have a second monitor? Maybe something to do with which monitor it sees are your primary one?
Ling.
ScottR
I'm only using 1 monitor, never used to happen on the old iMac - only happens on the new Mac Studio w/ the separate screen.  I don't have any other monitors.  So unfortunately that can't be the issue.
