2023-06-07 03:53 PM
yesterday it worked normal today double click on program and it crushes
Solved! Go to Solution.
2023-06-07 04:33 PM
2023-06-07 04:11 PM
I have the same, but Archicad 25 macOS 12.1
2023-06-07 04:15 PM
I have the same problem, I tried to reinstall but still not working.
2023-06-07 04:28 PM
I just heard from our reseller there are problems @ graphisoft and they are working on a solution
2023-06-07 04:31 PM
I have the same problem.
I have also been in contact with our reseller and they are also being called flat with the same problem.
I hope There is a fast solution.
For now , if jou have one archicad open,don't close it 😉
2023-06-07 04:33 PM
i updated archicad and it works for now
2023-06-07 04:36 PM
there is no (recent) update. most recent v26 doesn't crash. most recent v25 does crash on opening. it's a big bug currently at Graphisoft HQ
2023-06-07 04:38 PM
I have taken the internet off. started archicad and then plugged in the network cable again
2023-06-07 04:46 PM
that's a good workaround! thanks!
