We value your input!
Installation & update
archicad 8 crashing
Both ARchicad 8 and plotmaker have been running great for several years on my mac g5 computer. Then all of a sudden whenever I quit AC it crashes, Pm the same deal.
So I talked to tech suport, send bug reports, checked preferences( which are not where tech support thinks they should be) , fixed disk permissions, upgraded to OSX 10.4, drank coffee, deleted scratch files, optimized disk, memtested my ram.
Problem still persists, though I lose no work upon crashing thank god. i am in the process of upgrading to AC11 but still need to fix AC8.
any ideas? and thanks for your kind help. Bill
mac G5 dual 1.8, 1GB ram
Aussie John
Just dont quit Archicad any more!!
I would suggest you create a new account on your computer and reinstall archicad. Try your files in the new account. Dont install any other software. Disconnect any peripherals. This will help narrow the range of possible problems. It may work just fine. If it doesnt it points to something in the later versions of the OS causing a conflict with Archicad.
If it does work ok you will need to start adding other bits and pieces gradually to track where the error might arise. It is possible you might have eliminated the problem with the new user and reinstall.
Just wondering aloud - it is possible a font could be the problem?
Cheers John
[/size]
Okay, I logged in as a different user and I was able to open and quit both AC and PM without a crash. I did recieve warnings in AC and PM had an error 259; creation of file failed. I did not turn off peripherals or reinstall archicad as a new user yet. Bill
This issue was finally resolved by doing a clean install as a new user. I created a new account with administration privileges and reinstalled from there. To do the clean install I physically deleted caches and moved my preferences(which I later deleted). I never did find a good description of exactly how to do a clean install.
thanks for all the help folks, bill
