Installation & update
archicad replacement icons (mac)
schagemann
dear all,
i am sure we are not the only one who struggle following which AC version you are currently working in, particularly since the default AC logo has remained unchanged for quite some time...
... and so we decided to create our own and make it available for everyone - actually since we are trained architects like most of you, we made a few options...
1. column: transparent white outline
2. column: white
3. column: transparent
please download the respective versions from the following posts.
enjoy,
ds.
macinteract
Design Technology Managers - all  on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
36 REPLIES 36
schagemann
A brand new version for AC20 - ever so slightly improved...
https://macinteract.com/ac20-replacement-icons/
Also as the above download links seem to have broken with our recent website update (check it out... ;0) please find below updated links to all the previous downloads in chronological order:
https://macinteract.com/ac19-replacement-logo/
https://macinteract.com/ac18-replacement-logos/
https://macinteract.com/ac17-replacement-logos/
https://macinteract.com/ac16-replacement-logos/
https://macinteract.com/ac15-replacement-logos/
https://macinteract.com/ac14-replacement-logos/
https://macinteract.com/archicad-replacement-logos/
macinteract
schagemann
And for AC21 a slight deviation from so far almost religious following of the Graphisoft branding - looks like we are growing up after all...
https://macinteract.com/ac21-replacement-icons/
macinteract
schagemann
And so we forgot to post our ARCHICAD 22 replacement logos...
https://macinteract.com/ac22-replacement-icons/
macinteract
schagemann
And now for some ARCHICAD 23 replacement icons for completeness sake...
https://macinteract.com/archicad-23-replacement-icons/
macinteract
schagemann
What a change for 2020... Graphisoft has rebranded!
So without any further ado here are our alternative / replacement icons for ARCHICAD 24.
To ease the transition to the new identity for die hard / nostalgic ARCHICAD users, we have also included a LEGACY version...
https://macinteract.com/archicad-24-replacement-icons/
macinteract
schagemann
It took us more than a year to realise that we did not post the replacement logo for Archicad 25, so here a double post for both AC25 & AC26... enjoy!
https://macinteract.com/Archicad-25-replacement-icons/
https://macinteract.com/Archicad-26-replacement-icons/
macinteract
If only Graphisoft would do this. šŸ™„
25 & 26 are so similar it is ridiculous.
At least 24 & 25 had a different shape.
Barry
Just for completeness sake, it seems GS might finally consider a proper solution and save us the trouble each year...
https://community.graphisoft.com/t5/General-discussions/Archicad-Launch-icon-Can-you-spot-the-differ...
macinteract
schagemann
Hurrah another version...
https://macinteract.com/archicad-27-replacement-icons/
macinteract
Lee Hankins
Please be very wary doing this. We replaced the icon on one of our macs and it triggered Archicad in to thinking it had been pirated which caused us a bit of an issue with Graphisoft having to explain ourselves.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
