__archiben
archistair numbering . . .
hi fabrizio! (ben #3?!)
trying to place some archiStairs and having a little trouble with the numbering . . .
i searched here and found out that i could fix the angle of the numbers, and, as my stair is 'upsidedown' on plan i need to do this. but when i do this, the numbers jump to slightly off centre of the stair when i actually wanted them in the position they were originally - i.e. following the edge of the stair.
am i missing something obvious . . .
~/archiben
b e n _ f r o s t
6 Replies 6
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Hi Ben!
I should answer you only after three or four beer but, just for this time, I will provide you with a discont!
I will check this later (today I'm not at office) but, in the meanwhile you could fix this trouble by using the editable hotspot near the first number: dragging it you can fix the position of these texts...
BTW, did you plan to go to the next ACUE?
It's should be amazing meet you again...
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
__archiben
sorry fabrizio - i can't seem to get that working . . .
there is a single editable hotspot near one corner of the stair, but it doesn't do anything . . .
at the moment i don't think i'll be heading to the ACUE this year. it's a long way to fly! but then again . . .
~/archiben
b e n _ f r o s t
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Ok Ben,
please send me privately your PLN file (if you can only the Stair and, please, don't use the PLA format) I will check it later if I will be able to connect.
In the worst case I will connect this time and I will reply you ASAP.
No ACUE? What a pity... we should find another occasion... find something of interstesting near you and I will fly there!
Friendly
Fabrizio
Fabrizio Diodati
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Thanks Ben!!!
I just uploaded ArchiStair 1.10 at www.cigraph-store.com
This maintenance release fixes the trouble you pointed out: the editable hotspot for the text info offset definition didn't work.
Now you can solve you trouble by dragging this hotspot.
Thank you again for your precious help,
Friendly
Fabrizio
Fabrizio Diodati
__archiben
thanks fabrizio!
downloading at the moment . . . just a quick note to let you know that it doesn't work when using the 'Update' command from the archiStair menu. should it?
cheers and thanks again!
~/archiben
b e n _ f r o s t
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Hi Ben,
I simply uploaded the latest version: I had no time to update also that issue, I'm going to do so today!
Friendly
Fabrizio
Fabrizio Diodati
