can not start archicad 9
I installed archicad 9 as administrator in a computer. The operative system is windows xp, registered on a server 2000 domain. When other user than administrator try to use archicad, get the error: Application failed correct initialization (0xc0000022). Can somebody help me?
13 Replies 13
I haven't solved my problem yet.... and i really don't know what else to do... I've installed the correct Wibu keys, i signed in as an Administrator... i installed all the necessary software... java etc. Please.... it is kind of urgent. If anyone knows... Somebody told me that i should clean the registry first. Is that the case? I really need your help.
Djordje
Is your QuickTime installed?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Yes it is definitely installed. I have the Quicktime version 7. I think that it is the latest version.
This is a weird one. I have the same cpu, so it isn't the AMD.
I would recommend checking the application log for errors. Try to start ArchiCAD and then immediatley right click on My Computer and choose Manage from the context menu.
When the Management Console window opens expand Event Viewer (I think) in the left pane and then highlight the Application log. Look for any errors that just happened since you tried starting AC. If none are there also check the system log.
Post some screenshots of the logs if you can.
