can not start archicad 9
I installed archicad 9 as administrator in a computer. The operative system is windows xp, registered on a server 2000 domain. When other user than administrator try to use archicad, get the error: Application failed correct initialization (0xc0000022). Can somebody help me?
13 Replies 13
I don't think it is an ArchiCAD problem. I would guess it is something more fundamental.
Maybe virus, maybe unstable operating system, maybe faulty hardware. Hard to tell from this.
Edcad,
did you manage to solve this problem, I have exactly the same symptoms after installation of Archicad 9u.
Archicad will run as an local or domain adminstrator but not as an ordinary user.
It returns:
Application failed to initialize properly (0xc0000022) Click Ok to terminate the application.
Pieter
Djordje
Pieter wrote:
Edcad,
It returns:
Pieter
AFAIK, you have to be a power user at least, inthe standard Windowspeak
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordie,
Thanks for the information.
Do you know, or can you point me towards any documentation of exactly what rights are needed in order to allow an ordinary user to run the software as giving all our archicad-user students Power User rights is a bit of a blunt instrument and a possible security problem.
Pieter
I have the same problem:
After installing ArchiCad 9 as an administrator I got the following error message:
Application errors with error "0xc0000022 failed to initialize"
I cannot run so many programs etc Antivirus programs, and of course ArchiCad, when I log in to windows as a normal, or a power user! I can only use my computer normally when I log in as an administrator! But it's not secure! I'm sure it's the bug of the ArchiCad, not a virus or a malware program!
I solved the problem! I changed the user called XY from normal user to administrator than run the setup again. I chose the REPAIR function than changed back the user XY from administrator to simple user.
Important! If you do the same method as the original administrator it won't work!
Good luck!
I have got this problem....
I installed ArchiCAD 10 but i cannot launch archicad window. It seems as though it tries to launch but it closes immediately. I have an AMD computer and i think that is the problem because on a pentium computer it works just fine as far as i know. The components are:
Processor: Athlon 4800 2,4Gb
Memory: 2Gb
Motherboard DFI
Graphics Card: 7600GT
i tried to install the new Wibu keys but it didn't work either.... nor did the student version i had previously downloaded.
Please... could anyone help me??
Djordje
Did you install as an Administrator?
Djordje
HP Omen
Yes I believe so. If by Administrator you mean the computer's default user and not the guest user, yes that is what i did... i think. I mean... all my software has been installed this way i guess. Maybe there's something i misunderstood, could you please lead me through how to install from the beginning?
Thank you so much!
