heathldesign
can't repair installed AC27
i just tried to repair my installation of AC27, but when i start the installer i get a mesg that says "Archicad 27 cannot be installed into folders that contain other data. select an empty folder or create a new one." this is a first for me.
Operating system used: Mac Apple Silicon Ventura 13.6.3
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
1 Solution
heathldesign
thanks everyone. user error. my installation is USA and i tried to repair with INT. Duh.
Go to post
11 Replies 11
Eduardo Rolon
Seen something like this when you have installed extra Add-Ons like Enscape, Twinmotion, etc
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
heathldesign
not in this case, no add ons at all.
Eduardo Rolon
Weird. looks like you will need to trash the folder.
The other time I have seen this message is when you install AC into a folder and then change the name after installation finishes but that was in older versions IIRC.
AC29 US/INT -> AC08
heathldesign
nope. i've had to create a service ticket. we'll see what they say.
Aaron Bourgoin
why not just cut to the chase and do an uninstall / reinstall. that way you aren't worrying about all the under-the-hood stuff.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
heathldesign
that may be the fastest solution, i just hate going through the setup all over again if i don't need to. it may also be nice to know why it's misbehaving incase it's a symptom of something else.
Aaron Bourgoin
you'll never get the feedback as to what exactly is happening.
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Even if you 'repair' it, you will still need to reset your Work Environment, DXF/DWG translators, IFC translators.
A repair just saves you the process of un-installing.
Istvan Lengyel
The "Archicad 27 cannot be installed into folders that contain other data. select an empty folder or create a new one." message comes at the "New" installation, not in "Repair" mode.
At the end of a "New" installation, the installer saves "the installation information" (for example what what the selected folder for Archicad).
The Installer start in "Repair" mode only if the this "installation information" exists and the original Archicad folder exists and it is not empty.
In a comment above there is written, if the original Archicad folder is renamed, the installer cannot find it, so it start as a "New" installation, not in "Repair" mode.
Or if the "installation information" was deleted, the situation is the same, the installer starts as a "New" installation.
And the "New" installation accepts not existing or empty folder.
