code key error
I have version 8.1
The green code key is not recognizing the key.
Reloaded new driver from (Microsoft and Archicad)
And reloaded program with no luck.
Also, there is no support for 8.1 (2002 Version)
Any Ideas??
I am guessing it may have to do with the fact you are trying to run old software on a new operating system for which it was not designed.
8.1 was back in the days of Windows XP.
What is your OS?
Does Archicad run in demo mode or not at all?
If demo mode then there is a problem with your key.
If not at all it may be the OS.
Have you tried the license activation tool to see if the key is being recognised and the license is valid?
Can be found here ... http://www.graphisoft.com/downloads/licensing/
