Installation & update
disable palette on archicad 10
Dear All,
I have a really stange problem on my computer when installing archicad
10 INT. Some of the palette does not display the pictures related to the tools. I get some empty white window instead. The problem is definitely related to the OS or the video card driver because I have this problem only on this computer. Other computer with the same Turkish Os (XP pro) and the same video card does not get this trouble. I have installed new driver (INTEL (R) 82845GL extreme card) without success.
I joined a "screen print" to let you appreciate the issue. There is somehow
something wrong with a dLL but which one and why. Note that archicad 10 turkish is not better related to this issue.
Do I have a virus or another program is sharing the same dLL ?
Thanks for any help
Regards
Jean-Luc
[/img]
8 REPLIES 8
Hello, I just wanna tell you I tooo have the same problem, I just wish someone solves it for us . I even formatted all the drives and reinstalled but with no success at all.So, by the way all the best.Maybe like me just try working on another system. God bless you dear
Djordje
As already concluded in other dicsussions on the same topic:
Run Windows update. You need XP Service Pack 2 to run Archicad 10.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
"As already concluded in other dicsussions on the same topic"
"Run Windows update. You need XP Service Pack 2 to run Archicad 10"
Ah? that was the conclusion ?. I propably did not understand so.
I have two computer with xp home service pack 1 and it works...
TomWaltz
It may work on that machine, but you might run into other problems running SP1.
Unless you have a reason to avoid the update, you might want to try it before you rule it out.
Tom Waltz
Djordje
AFAIR JeanLuc had trouble installing SP2 and had to revert to SP1 ...
... his machines did not like SP2 for wahteevr reason.
Correct?
Good that you solved your problem.
Djordje
HP Omen
I do not rule out the fact that installing xp SP2 solve the problem in certain case.
I just notice that archicad works with SP1 on both machines
and thank about the "FAIR" I hope you don't have any doubt about it hum?
Djordje
AFAIR=As Far As I Remember ...
Djordje
HP Omen
mea culpa
