2006-01-03 02:33 AM
2006-01-03 10:51 AM
2006-01-03 01:26 PM
2006-01-03 03:10 PM
Donald wrote:At 100% Zoom, the screen should look almost like the actual plot. 100% Zoom is a litte closer than most people work, but it works fine for me. Does yours not work?
Matthew Lohden said:
Remember that he screen is a low res device compared to printed matter. You need to zoom to 2 - 4 time actual size the really see line weights accurately on screen.
I don't accept your explanation.
It is true that in archicad you have to zoom way in o see any line weight differences but even then the weights are not accurately presented.
I don't have to zoom in like that in other programs like say illustrator, photo shop, rudimentary 2d drawing programs.
Also, isn't it interesting that that in plotmaker, on that same low res screen, i don't have to zoom in at all : the line weight differences are completely apparent.
Its a problem that should be fixed.
donald mac donald
mac g5, archicad v9
2006-01-03 03:38 PM
2006-01-03 03:49 PM
Donald wrote:The pen settings in Archicad would need to be the same as Plotmaker's in order for them to look the same. It's kind of a reverse matching: Make sure Archicad's pen weights/thicknesses match the ones being used in Plotmaker so that they look the same.
at 100% zoom, display options set to true line weight all the line weights look the same even though the pen weights as set in archicad are very different. i've checked the manuel and it says i should see the difference. i do not.
in plotmaker i see the difference. but not in archicad. i don't see how setting archicad and plotmaker pen weights the same would change this situation. my problem is in archicad, not plotmaker.
donald mac donald
mac g5 archicad v9
2006-01-03 04:00 PM
2006-01-03 06:23 PM
2006-01-03 06:54 PM
2006-01-03 07:16 PM
