Installation & update
doors and windows
Bobby_ja_tt
hi all
im having a problem with displaying my doors and windows on my plan
the doors/windows are displayed in the settings menu ,the section and the 3d window
but not the plan window..can anyone help me with this problem please.
regards
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
2.8 GHz Intel Core i7
16 GB 1600 MHz DDR3
__________________
10 REPLIES 10
David Maudlin
Bobby:
Check your Model View Options. You should create a Model View Option Combination with the desired settings and assign it to the View in the View Map.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Bobby_ja_tt
hey dave
thanks for replying
i did that before
it does not work...
see the attached image
thanks
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
16 GB 1600 MHz DDR3
__________________
David Maudlin
Bobby:
The only way I could replicate your image is by setting the Model View Options for doors and windows to "Show Opening Only", I couldn't replicate this with various settings for the walls, doors and windows using the Floor Plan Cut Plane, but the problem might be there: are the doors, windows and walls set to "Symbolic"? Perhaps posting some screen shots with your Model View Options, Door, Window and Wall settings will help someone figure out the cause of your display problem.
HTH
Bobby_ja_tt
hi dave
here are the screen shots
floor plan cut plane is at its default but i think u might be on to something with that idea because my model is not at the default zero level
im gonna try that.... did not work
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
16 GB 1600 MHz DDR3
__________________
Bobby_ja_tt
model view options
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
16 GB 1600 MHz DDR3
__________________
Bobby_ja_tt
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
16 GB 1600 MHz DDR3
__________________
Chazz
How's it look in 3D?
Nattering nabob of negativism
David Maudlin
Bobby:
The Model View Options look good, so you might want to check some display options for the walls, doors and windows: you should set these to "Symbolic" (this ignores the Floor Plan Cut Plane, although yours looks reasonable if your units are millimeters). For the doors go to Door Settings > Floor Plan Display > and set to "Symbolic", same location for the windows, and for the walls go to Wall Settings > Floor Plan and Section > Floor Plan Display and set to "Symbolic". If that doesn't work, then I am afraid that I am out of ideas, hopefully someone else may have a clue.
Good luck,
Bobby_ja_tt
hello dave
thanks for your help that last thing you suggested worked
regards.
Robert Thompson
Ackee Workshop
_________________
Archicad 9-21 FULL
Rhino 5 (mac)
MacBook Pro
16 GB 1600 MHz DDR3
__________________
