elevation rotate !!!
Hello
I draw plans on 270 degree
after I put /elevations /section/and 3d documents
it come rotated !!
on 3d documants I corrected it because it has ortate view options
but in elevations is there any solutions ?
if I rotated it on layout text and dimentions come in wrong way .
thanks
I see you are using Archicad 23.
Do you have the latest update?
What happens when you set the plan back to zero and then create the elevation?
There is also an option in the view settings to 'Ignore zoom and rotation'.
thanks Barry.
first when use the ignore dose not work because the elevations still rotated
but after that I tried to change the rotate degrees on the plan and use previous to get right rotate of elevations and after that remove check from ( ignore zoom and rotation)
that works perfectly
thank you again
Minh Nguyen
Thank you very much for your report!
As Barry mentioned, it would be great to know if the issue happens on the latest update for Archicad 23 (currently 7000).
In the first Archicad 23 update, we fixed a similar bug:
  • 267879 DOCUMENT: Sections and elevations were rotated on views opened from view map.
Could you please let us know whether the issue persists on Archicad 23 7000?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
