ā2009-09-25 12:09 PM
ā2009-09-25 01:57 PM
ā2009-09-25 06:58 PM
David wrote:As far as 64-bit, the current iMac can have up to 8 GB of 1066MHz memory, which would likely be enough for most uses. ArchiCAD cannot use more then 4 GB today (still 32 bit on Mac), but if you are running two ArchiCAD sessions, and/or other applications, you could utilize the additional memory.
I have a few clients that have been using iMacs with AC10, 11, and 12 without any major issues. Just remember that you have hardware upgrade limitations with iMacs, so if you do plan to upgrade to more demanding software (64 bit) sooner rather than later you will have issues.
ā2009-09-26 09:46 AM
ā2009-09-29 07:39 PM
ā2009-09-30 12:19 AM
ā2009-10-02 11:27 PM
ā2009-11-20 06:39 PM
