Service alert: BIMcloud SaaS disruption in the US Read more
macOS 10.13 High Sierra
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
wp-content_uploads_2017_06_high-sierra-icon-150x150.pngApple released macOS 10.13 High Sierra on September 25, 2017. With the latest updates ARCHICAD 20 and 21 should be compatible with macOS 10.13. There are still a few minor glitches with ARCHICAD and BIMcloud, as well as some High Sierra specific behaviours, but these shouldn't hinder production work. You can find out more about these in the linked articles below.
ARCHICAD compatibility by different versions
Supported versions
  • ARCHICAD 23: Supported for all language versions.
  • ARCHICAD 22: Supported for all language versions.
  • ARCHICAD 22 Solo: Supported for all language versions.
  • ARCHICAD 21: Supported for all language versions (with update 5021 or higher).
  • ARCHICAD 21 Solo: Supported for all language versions (compatibility update coming soon).
  • ARCHICAD 20: Supported for all language versions (with update 7001 or higher).
  • ARCHICAD 20 Solo: Supported for all language versions (compatibility update coming soon).
  • ARCHICAD STAR(T) Edition 2018: Supported for all language versions.
Not supported but compatible versions (can be installed, but bugs and issues may occur)
  • ARCHICAD 24 and newer: Compatible for all language versions, but not tested and not supported with compatibility updates.
  • ARCHICAD 24 Solo and newer: Compatible for all language versions, but not tested and not supported with compatibility updates.
  • ARCHICAD 19: Compatible for all language versions, but not supported with compatibility updates.
  • ARCHICAD 19 Solo: Compatible for all language versions, but not supported with compatibility updates.
  • ARCHICAD 18: Compatible for all language versions, but not supported with compatibility updates.
  • ARCHICAD 18 Solo: Compatible for all language versions, but not supported with compatibility updates.
  • ARCHICAD STAR(T) Edition 2017: Compatible for all language versions, but not supported with compatibility updates.
  • ARCHICAD STAR(T) Edition 2016: Compatible for all language versions, but not supported with compatibility updates.
Not compatible versions (can't be installed)
  • ARCHICAD 17 and older: Not compatible with macOS 10.13 High Sierra
  • ARCHICAD 17 Solo and older: Not compatible with macOS 10.13 High Sierra
  • ARCHICAD STAR(T) 2015 and older: Not compatible with macOS 10.13 High Sierra
Known issues
ARCHICAD
OS Specific behaviours and remaining issues: Fixed issues:
BIMcloud, BIMcloud Basic (formerly BIM Server)
Fixed issues:
