plotmaker won't update
I have archicad version 8.1 and plotmaker version 9. When I try to update the links in plotmaker I get an error message that reads "Plotmaker could not launch ArchiCad because it does not know Archicad's path on your computer. Archicad may not have been installed or launched on this computer yet."
Is this because I'm using the two different versions? Or is it a Windows XP issue? Any help would be appreciated.
10 REPLIES 10
One thing is that I found that you cant have plotmaker 9 and Archicad 10 open at the same time. Also, you need to save your file in ArchiCAD 9 before you can update it in Plotmaker 9.
