Installation & update
printing problem(s)
I wonder if somebody could help me on this.
I have Archicad 9 english version.
I didn`t have had any problems until I reinstalled windows, but after I cant`t print at all.
As I send a print command(happens the same with printing into pdf),the application crashes and a bug reporting window appears.
Please answer quickly.
Thanks!
4 REPLIES 4
You might try uninstalling your printers and reinstalling the printer drivers. You didn't indicate your version of Windows but the printer drivers may not have installed correctly on your reinstall of Windows.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Also, if you want PDF's I have been reliably informed that you're better publishing than printing in AC9/PM9.
This might help.
I`ve uninstalled and reinstalled my printer, but I still can`t print.As soon as I hit the print button the application crashes.
I have winXp sp2 hungarian.
Intel celeron 2.4 GHZ
512 ddr
Canon ip1000 printer
I`ve rainstalled AC 9 as well but still won`t print. I`ve installed AC 8.1 too, and with this one I can print, it works fine.
Any new solutions?
