problems with amd ryzen 5 2400g in archicad 21
How about, I have problems with ac 21 to visualize in 3d, I have a processor amd ryzen 5 2400g and graphics processor vega 11, someone knows what I can do to correct this problem, I would greatly appreciate your help
4 Replies 4
Eduardo Rolon
Question does not make sense, what problem do you have in 3D?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Lingwisyer
Guru
Can you provide some screenshots of your issue?
Ling.
I would hazard a guess that the hardware that Eliel is using is significantly underpowered for general Archicad use let alone visualisation. The processor stated with integrated graphics is underpowered for AC let alone integrated graphics do not meet minimum specifications for AC
Regards,
Scott
Lingwisyer
Guru
Hm. The "and" threw me from the integrated GPU. AC is not designed to run on a sub AU$400 computer...
Ling.
