published fonts garbled on mac but fine on PC
Gus
Our office used both Mac and PC. However when printing from some projects through a MAC all the fonts are garbled even though they print fine from a PC. Does anyone out there have any ideas about why this might be happening?
Thanks in advance
-Gus
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
4 REPLIES 4
I assume you mean the fonts are garbled on-screen, rather than when printed, so that it is not a printer driver issue?
Check some of the text elements of the offending project on the Mac. Are any of the font names enclosed in square brackets, such as [Arial]? The square brackets mean that the matching font is not available... happens on both Mac/Windows for any project. This could be the issue?
I've not seen this issue in 8 or more years... but way back when, it would be the localized version of a font that wouldn't come across correctly... for example, Arial Western on one machine would appear as Arial Cyrillic (e.g.) on the other and wouldn't work until I manually changed it.
One of the forum moderators
Gus
No, the fonts are fine on screen but they print garbled.
Madison WI
Are you printing to the same printer, with the most up-to-date drivers for it? While OS X comes with basic support for a variety of printers, you typically need to go to the manufacturer's web site for the most current software.
Your signature has the specs for a Windows machine... what are the specs for your Macs? What printer?
Does this happen when you print from a view as well as from a layout or publisher set that is configured to 'print'?
NCornia
I am pretty sure this is the issue: http://www.archicadwiki.com/Troubleshooting/UnreadablePdf But luckily this is addressed in .AC17 Hotfix #4 (Build 5005)
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
