Yes, but it is slightly different. With a multi-plane gable - mouse down upon seeing the Mercedes cursor on the gable edge of the blue "wall outline" rectangle/geometry as seen in the attached screenshot. (This blue geometry typically corresponds to the outside edge of the walls below - the roof overhang values etc are defined relative to this.)
This process differs from single plane roofs where you get the Mercedes on the edge of the roof itself.
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
