2010-01-29 10:00 AM
2010-01-29 11:22 AM
kombibob wrote:Robert, had similar occurrences and moving the Elev/Sect marker closer/farther only slightly sometimes works.
any suggestions welcome.
2010-02-02 06:55 AM
Rod wrote:hi Rod,kombibob wrote:Robert, had similar occurrences and moving the Elev/Sect marker closer/farther only slightly sometimes works.
Last time had to copy all 2D elements then redo the same view paste back 2D elements and all was ok. HTH
2010-02-02 08:18 AM
2010-02-02 09:37 AM
Matthew wrote:I thought that may have been the case, however when i viewed the layout that contained the drawings that were missing the lines, i used right-click and 'open source view' to check. i don't think there's a change in layer combination that occurs here. I'll have to go back and check.
It is possible that the layer combination for the drawing is not the same as shown in the elevation window.
