Installation & update
v23 monitor flashing between workspaces
lasse
Can't figure this one out. Has anyone seen this or solved this:
When activating windows (tabs) between workspaces (layout, plan, section, 3D window, etc), monitor(s) flash/blink/go white. There's a delay in refresh, redraw, but super annoying strobe effect going on. Sometimes its all white until I pan around.
My setup is an iMac Pro with (2) separate BenQ 32" monitors. Has worked seamlessly with previous versions and all other applications. NOT v23! I always have 3 floating windows in my workflow in addition to the requisite tabs (3D and palettes in one window, floor plan+tabs in the middle monitor, sections and elevations in the right).
• I tried screen mirroring - still occurs
• I tried ONLY the iMac Pro monitor - still occurs.
• I tried the standard template without any of my preferences and customization - still occurs
• I tried a new and reset template - no dice!
C'mon.....really??!?!? I'm not usually an early release adopter, but I was curious. Going back to previous versions......again.....
Lasse
Setup:
Model Name: iMac Pro
Processor Name: Intel Xeon W
Processor Speed: 3 GHz
Number of Processors: 1
Total Number of Cores: 10
L2 Cache (per Core): 1 MB
L3 Cache: 13.8 MB
Memory: 64 GB 2666 MHz DDR4
GRAPHICS: Radeon Pro Vega 64 16 GB
Version Lang Build Platform Type
23 USA 3003 Mactel64 FULL
(unnerved by updates since v.4.55)
Erwin Edel
I have no solutions, but what version os OSx are you using? That might clue someone in as to what might be going on.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
lasse
Ooops - thought was in there when I copy/pasted my system info
MACOS 10.13.3 (17D2047) ~ a "supported" OS
Thx - L
