2009-09-22 09:40 AM
2009-10-14 12:10 PM
2009-10-14 08:11 PM
laszlonagy wrote:Exactly. We ran this way during the beta; quick and easy; works fine.
This should be easy to do:
1. Upload the MEP Library to the BIM Server.
2. Add it in the Library Manager as a BIM Server Library.
2009-10-15 12:20 AM
2009-10-15 03:06 AM
Steve wrote:I think it must be, but not sure what it would be? Everybody during beta - and still Erika and I that I know of now, have no problem with MEP and TW2.
It is probably operator error of some kind but I sure don't know what it is.
2009-10-15 03:35 AM
2009-10-15 12:28 PM
2009-10-15 06:06 PM
laszlonagy wrote:The second screen shows the Warning I get when I click Start Routing.
Steve, on your third screenshot I am not seeing the MEP Library set among BIM Server Libraries.
First, you have to upload the MEP Library to the Server. That is one thing.
But then you have to go to the Library Manager and add that uploaded library to your project.
There is a tricky thing. When you share a Project, ArchiCAD can automatically upload the linked library of that project to the BIM Server and load it as a BIM Server Library. But when adding libraries later you need to do it this way.
2009-10-15 06:34 PM
Erika wrote:I guess it must be someting wrong on my end.
Yup, no problem here. MEP works fine.
2009-10-15 07:15 PM
Steve wrote:Not sure what you're talking about here? I've never had a problem with TW2 and the MEP library.
It did not work for Karl either at time because the prior cashed copy of the library was still in his TWData folder or someting. Shall I post some screen shots of that?
2009-10-15 07:39 PM
