2 separate objects have the same GUID?
JGoode
I have 2 separate objects but they both have the same GUID somehow which is making migrating a nightmare. Is there any fix for this besides doing a save-as so the guid changes?
Thanks
ArchiCAD 23
Windows 10
runxel
Hero
I think this might be already actually the quickest solution.
You could also convert it the gsm to XML and then change the GUID by yourself...
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Nader Belal
Mentor
Easier solution in 2.5 steps:
Step 1: Select one object of your liking and open it in the GDL Editor
Step 2: Save it in any location of your liking (saving it in the same place with the same name will just do it)
Step 2.5: Make sure to click on "Create New Library Part" as seen in the picture below.
