JGoode
2 separate objects have the same GUID?
I have 2 separate objects but they both have the same GUID somehow which is making migrating a nightmare. Is there any fix for this besides doing a save-as so the guid changes?
Thanks
ArchiCAD 27
Windows 10
runxel
I think this might be already actually the quickest solution.
You could also convert it the gsm to XML and then change the GUID by yourself...
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Nader Belal
Mentor
Easier solution in 2.5 steps:
Step 1: Select one object of your liking and open it in the GDL Editor
Step 2: Save it in any location of your liking (saving it in the same place with the same name will just do it)
Step 2.5: Make sure to click on "Create New Library Part" as seen in the picture below.
