‎2017-01-17
05:57 PM
‎2023-05-24
11:37 AM
Rubia Torres
‎2017-01-18 06:04 AM
values{2} "view_select" 1, "View 1", 2, "View 2", 2, "View 3"
(You can customize the "" sections with the friendly names of Your views)if view_select=1 then fragment2 1,0You have to have the content of the view 1 on the "1" layer in the 2d symbol and so on.
if view_select=2 then fragment2 2,0
if view_select=3 then fragment2 3,0
‎2017-01-18 11:43 AM
‎2017-01-18 01:50 PM
Joeyjojo wrote:For this parameter as Piotr described it, the "Typ" (Type) should be changed from Length to Integer so it accepts only integer numbers.
1. I create a new parameter in the Parameter window and name it view_select in the 'Variable' cell, right? Then I put a number in the 'Wert' cell, for example 1? Or 3?
‎2017-01-18 06:10 PM
‎2017-01-19 10:27 AM
‎2017-01-19 07:51 PM
‎2017-01-19 11:20 PM
‎2022-03-25 02:55 PM
Thanks Piotr ! Really useful !
