2D Object as complex profile
Dear all
Is there a way to place the complex profiles as a 2d object, making it also possible to strecht (for the profiles that have this option).
I want this to be able to draw in worksheets.
Thanks in advance
9 REPLIES 9
I think it can be done by "simple" REQUEST.
But honestly... My GDL kungfu is not that strong.
Hope that helps.
n = REQUEST ("Profile_default_geometry", name_or_index, n1, n2, ..., nm,
            x11, y11, edgeVisible11, vertEdgeVisible11, additionalStatus11, ...,
            x1n1, y1n1, edgeVisible1n1, vertEdgeVisible1n1, additionalStatus1n1,
            x21, y21, edgeVisible21, vertEdgeVisible21, additionalStatus21, ...,
            x2n2, y2n2, edgeVisible2n2, vertEdgeVisible2n2, additionalStatus2n2, ...,
            xm1, ym1, edgeVisiblem1, vertEdgeVisiblem1, additionalStatusm1, ...,
            xmnm, ymnm, edgeVisiblemnm, vertEdgeVisiblemnm, additionalStatusmnm)
Dear Braza,
Thanks for sending me that code.
I tried pasting it on the 2D script but i got an error. Should i place something else before?
My GDL kunfu is almost 0
Well... In this case, I strongly advice you to RUN! As fast as you can!
Now seriously: You could try using the CP you want in a column > edit as you wish > Ctrl+c the column > Paste it in your worksheet as 2d elements. It wouldn't be "Alive", but you could easily edit it in plan and paste it again. Or you can join us in the Wish Session Club (AKA "AC Beggars").
well thanks anyway.
Yeah i wanted something that updated automatically, so i could use it both for the 3d but also for the 2d details.
Thanks anyway. I will add it to the wishlists
DGSketcher
Legend
You could do as Braza suggested but place the column on a "hidden" storey below your main model. The "columns" would then be live to use any offset modifiers or general changes to the profiles. You can then place this storey on your layout and adjust the frame to only show the relevant "column".
runxel
Hero
Luiscardoso wrote:
Is there a way to place the complex profiles as a 2d object, making it also possible to stretch?
No. AFAIK the modifiers are disabled when the profile is used in objects.
EDIT: I am right. Look into the docs for more info.
Lingwisyer
Guru
Well... if you do not mind stretching uniformly, you can always use the MUL command.
runxel
Hero
True! That's what I ended up doing here. Have fun with it! 🙂
oh thanks a lot!!!!
