2D object line types
Llian
I have saved an object from a 2D using the save selection but I am puzzled why the dashed lines are in solid line. Here's the screenshot...the right is the 'object'.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
If you select the placed new Object and go to its Settings Dialog, in the Floor Plan and Section panel, is the "Override Object's Line Types" checkbox checked?
Does it work if you uncheck it?
Llian
Thanks...yes it works....now how do I make changes to the object...where is the explode tool?
