2D object line types
Llian
I have saved an object from a 2D using the save selection but I am puzzled why the dashed lines are in solid line. Here's the screenshot...the right is the 'object'.
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
If you select the placed new Object and go to its Settings Dialog, in the Floor Plan and Section panel, is the "Override Object's Line Types" checkbox checked?
Does it work if you uncheck it?
Llian
Thanks...yes it works....now how do I make changes to the object...where is the explode tool?
Lilian Seow
