360 masonry arch.
Tom Krowka
There is a handy little masonry arch object in Masonry, Wall object, but it only completes the top 180 degrees of a circle. Is there any way to make it a 360 degree arch?
I have a round window & I would like to put a brick trim all the way around it. Can't figure out how to mirror it, extend it, copy it upside down, or do anything to it so it would give me the bottom half also.
If that does not work, any ideas on how to actually make a round trim?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
4 REPLIES 4
Erika Epstein
What about the round window and turn on the brick trim?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Save it as an object from bottom view and reinsert it!
Tom Krowka
There is typical brick molding on the round window, and I guess I could make it 8 inches thick. but it does not give a brick look with mortar joints, etc. that the object arch does.
Am using the special edition AC9 library.
Thomas@wkarchwk.com
www.walshkrowka.com
gpowless
Brick Arch at Objects Online does the trick. I've used it on a number of projects.
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
