Steve Jepson
3D Nuts & Bolts
I need some 3D nuts, bolts, and washers. Does anyone know of any .gsm parts like this?
This is not good enough. I want threads.
Can anyone tell me it this is a GDL script ?
http://softlayer.dl.sourceforge.net/project/boltfactory/Bolt%20Factory%20for%20Blender%202.5/Bolt%20...
17 Replies 17
Erich
Steve wrote:
Can anyone tell me IF this is a GDL script ?
Steve,
No it is not.
I think the GDL Cook Book has a 3D bolt script in it. However, I haven't looked at it in a long time.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Yep the cookbook has a script for this. In fact, I recently made a parametric bolt, nut and washer combo based on standard sizes. If someone will remind me on Monday, I'll post it.
Nuge
Steve,
Try this Cadimage object
http://www.cadimageworld.com/downloads/Item/340-bolts
Nuge
AC27 i9 14900KF / 128G ram / GTX 5090 / D5 Render
Steve Jepson
the CADimage bolt I tried wont let me set the dia. to 2 1/2".
Nuge
Steve,
Ask them to open the code so you can add in the sizes you need.
Nuge
Brett Brown
Nuge wrote:
Ask them to open the code so you can add in the sizes you need.Nuge
Should have been fully parametric in the first place.
Check out the fully parametric bolt I just posted to the depository.
too bad I don't have AC 14. 🙂
I could probably take this back to AC12, but not AC10. Your standards in Brazil are probably different anyway.
