3D Nuts & Bolts
Steve Jepson
I need some 3D nuts, bolts, and washers. Does anyone know of any .gsm parts like this?
This is not good enough. I want threads.
Can anyone tell me it this is a GDL script ?
http://softlayer.dl.sourceforge.net/project/boltfactory/Bolt%20Factory%20for%20Blender%202.5/Bolt%20...
17 REPLIES 17
yes, this dual standard still does not make sense to me, just like the
annual version policies.
Anyway. Just have to wait for the next upgrade.
I assume that Brazil, like the rest of the civilized world, uses metric. We're still stuck with the English system. A system so bad, the English no longer use it! When I get some time, I'll make a metric version in AC12.
Yes, we do use the metric, not the "imperial" system.
I guess the U.S. is the only country that still uses inches and that weird 1/8
1/16... although when I was living near Denver, the guys there always tried to teach me how to use feet&inches . 🙂 (With no result I must confess)
I will wait for your 12 or 13 version.
Thank you.
Paulo,
If you can direct me to a data base that contains standard metric dimensions, I can make a metric version.
I'm not sure what you're asking. Kind of a catalog?
The conversion is very easy. 1 inch = 25,4 mm
Ex: 3/8" = 9,525 mm result in 10 mm
1/2" = 12,7 mm result in 12,5 mm
I could not see your object, but most of the time, since the machines
used to build the nuts and bolts are made in GERMANY for the USA, they
use the imperial units.
It's not unusual you ask for a 1/2" - 12.5mm "something", old dealers understant de imperial and the young ones the metric. 🙂
I'm looking for standard dimensions. So yes, sort of like a catalogue. For the imperial version I found a table of dimensions for all the common bolt sizes. The table had for each bolt diameter:
• bolt head height
• bolt head diameter
• bolt head width (measured from flat to flat)
• thread distance (how many inches of thread if not fully threaded)
• washer thickness
• washer diameter
• and a few other dimensions I don't recall at the moment.
If I had a metric data base for the bolts you normally use, it would be easy to redo the object. The data can come in a variety of forms. If you find a table send it to me, I can probably work with it.
Gorazd
In this PDF you will find the standard dimensions for M1,6 to M36 bolts, nuts and washers. Hope it helps.
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
Perfect. That's exactly what I need. Thank you.
